close
TPC Reset
UboatSean
Trying to play WGT golf on my new laptop but I get the following:
error 8, the proxy failed to connect to the web server, due to TCP connection rejection (tcp reset)
any help or ideas would be appreciated
stephen
13 REPLIES 13
Jon_K
Former EE Employee
Hi @UboatSean.
Welcome to the community.
What router are you using?
Have you tried restarting your router?
Jon
Hi Jon, I’m using a 4GEE router, other websites seem to be working fine, it’s just when I try and load WGT.com, it’s a new laptop I’m really not that technical which is a shame. I will restart. The message I get when I try and load WGT.com, is Error 8 the proxy failed to connect to the web server, due to TCP connection rejection (TCP Reset)
regards stephen
Hi @UboatSean ,
Is the below URL of any help? You will need to be careful of removing any proxy or VPN settings which you genuinely need for your work. If you laptop is a personal laptop, it may be the case there should be no proxy or VPN set and in that case the below Microsoft-forum-related advice may apply.
https://answers.microsoft.com/en-us/microsoftedge/forum/msedge_issue-msedge_win10/error-code-8-the-p...
Edit: your mileage may vary and if you remove something which you actually require, the situation may actually be worse and become more misconfigured. Good luck!
Jon_K
Former EE Employee
Thanks @UboatSean.
Have you been able to access this website previously on this router?
Can you access the website using another router or provider?
Jon
Thanks Mike appreciate your help, will give it a go
regards stephen
@UboatSean : Is the site that app uses IPv6 compliant? It might be an EE IPv6 issue. EE has introduced IPv6 on its mobile network, but it doesn't fall-back to IPv4 nicely. Can you change the Profile/APN on your EE devices to APN Protocol = IPv4 only?
The two domains below have no AAAA records.
Edit: goofed up on my command, correcting:
[x@x ~]$ for i in {,www.}wgt.com; do dig AAAA @9.9.9.9 $i; done
; <<>> DiG 9.11.20-RedHat-9.11.20-5.el8 <<>> AAAA @9.9.9.9 wgt.com
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 12558
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;wgt.com. IN AAAA
;; AUTHORITY SECTION:
wgt.com. 300 IN SOA ns1v.datapipe.net. hostmaster.wgt.com. 297 10800 3600 604800 14400
;; Query time: 260 msec
;; SERVER: 9.9.9.9#53(9.9.9.9)
;; WHEN: Wed Jun 09 23:36:42 BST 2021
;; MSG SIZE rcvd: 100
; <<>> DiG 9.11.20-RedHat-9.11.20-5.el8 <<>> AAAA @9.9.9.9 www.wgt.com
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 31864
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 1, ADDITIONAL: 1
; EDNS: version: 0, flags:; udp: 1232
;www.wgt.com. IN AAAA
;; ANSWER SECTION:
www.wgt.com. 60 IN CNAME we6fuwt.x.incapdns.net.
incapdns.net. 297 IN SOA ns1.incapdns.net.incapdns.net. hostmaster.incapsula.com. 1001 3600 600 604800 300
;; Query time: 132 msec
;; MSG SIZE rcvd: 150
What does that mean in English, not computer code?
In response to "Is the site that app uses IPv6 compliant?": the domain names wgt.com and www.wgt.com have no AAAA records.
The statement was "The two domains below have no AAAA records." And below that statement was given the proof of that statement.
