30-08-2021 07:14 PM
I have had a Samsung watch attached to my contract for 2years now and changed the plan to the cheaper sim only option as the watch was fine. It now broken and I am buying another watch the same from a freind who doesn't use hers. Its LTE version also. Can I replace my existing watch with this one so it works with the watch sim.only.plan?
30-08-2021 11:17 PM - edited 30-08-2021 11:19 PM
@Lynsey2306 Yes you can. You just do all this from the ware app. You need to unpair you’re watch keep your data plan and then set up your new watch and reattach the data plan.
or alternatively give 30 days notice to terminate your current watch contract then unpair your watch and then set up your new watch and then purchase a new Sim only plan for that watch via the wear app.
