close
Samsung to Iphone
RebeccaMuir
  1. Is there any way you can swap a contract? I got a Samsung to try it out as I previously had an iPhone. I don't really like the Samsung I have, it isn't damaged in any way but would prefer an iPhone instead. Is there any way this could be done or an alternative way?
Alex_S
EE Employee
Hi @RebeccaMuir,
Welcome to the community 🙂
You can return your new or upgraded device within 14 days if you are not happy with the device or Upgrade you completed.
You would also have options to exchange the device depending on which Upgrade Plan you are on.
If you are on an Upgrade Anytime plan, you can change your phone after 15 days of your last renewal.
Alex 🙂
