26-10-2020 04:24 PM
I have a new Note 10+ with dual hybrid SIM card slots. However it won't let me use the SIM 1 slot - it keeps coming up as ' SIM 1 not allowed' - so I have to use the SIM 2 /hybrid slot where it works fine. Problem is it means I can't use my memory card or work SIM in the hybrid slot. This defeats the purpose of having dual SIM slots.
Can someone advise? Ive tried contacting via 150 and also live chat - but no access for tech support.
How you can help.
26-10-2020 04:28 PM
Hi @SDD
What SIM are you trying to use in the SIM1 slot? Is it an EE SIM or one from another network?
If it's another network, that could be an issue with the device being SIM-locked to EE.
26-10-2020 06:00 PM
I've only used my EE SIM so far - haven't attempted work SIM yet (O2) in either of the slots yet.
From what you're saying, the slot is locked to EE? But wouldn't that mean both are locked to EE? Then both should work for an EE SIM irrespective of which slot I use.
I wonder if that's the reason I can't get phone insurance with the IMEI given too?
26-10-2020 06:15 PM
You're correct to assume that if SIM locking applies, it would apply to both slots.
I'd agree that both slots should work for EE SIMs, but that was just something to clarify 🙂
26-10-2020 06:30 PM
Thanks Bristolian - forgot to add phone came from Metrofone - so not directly from EE.
Any idea how I can get this resolved?
27-10-2020 08:30 AM
Hi @SDD.
If you're SIM works in one slot but not the other, this would suggest no issues with your SIM card.
I'd recommend getting in touch with Samsung to see if they can help to identify a potential problem with the SIM slot.
Jon
27-10-2020 12:57 PM
Hi All,
I have just contacted Samsung and they have said it's not a problem with the phone - it is the network, and I should be speaking to the network provider to resolve this.
Is there any EE support available for this via this forum of I can't get hold of tech support?
27-10-2020 02:46 PM
Hi @SDD.
Did Samsung run through any troubleshooting with you to determine where the problem lies.
Are you able to get in touch with our Tech Care team?
Jon
27-10-2020 04:11 PM - edited 27-10-2020 04:13 PM
Well we were on chat for a good 50min -
Switching Airplane mode off and then on.
Turning phone off and then on.
Removing the SIM, cleaning and putting it back in.
Resetted the network settings.
Software is all up to update.
Provided IMEI numbers, purchase dates, ported numbers,
They concluded I needed to seek network help first.
I have tried to get hold of tech support on the phone and via web chat but access isn't available/allowed to tech support - hence I'm now here.
I'm sure i read somewhere else on thi forum the same issue and it was indeed EE that had to unlock the second SIM?
Note: bear in mind Sim 2 slot works perfectly for both SIMs - But I cant add my EE or O2 Sim to slot 1.
28-10-2020 08:25 AM
Hi @SDD.
If your EE SIM isn't accepted in the SIM slot, then it doesn't need to be unlocked.
Are you able to call our Tech Care team from another phone?
Jon
