close
S 21 PLUS
Rats110605
  1. Hi, I upgraded from S7 Edge to S21 plus but have not received a charging plug! Just a cable that doesn't fit the plug I have, how am I supposed to charge it!!
9 REPLIES 9
@Rats110605  Samsung don’t include it now. You can use a wireless charger or your old charger but if you purchase the correct plug it’ll charge.   You need a usb-c plug.
BrendonH
Community Hero
Community Hero
Speak to Samsung they decided that everyone has enough plugs from old devices.
You need to purchase one there are plenty on Amazon
Or you can use wireless charging.
BrendonH (Android Expert) Google Pixel 8 Pro Obsidian Black (Android 15)
OK thanks I just hope I order the right plug!🤔
https://smile.amazon.co.uk/Samsung-Original-Charging-Compatible-Smartphones/dp/B08446RFPX/ref=sr_1_5...
Northerner
Hi @Rats110605
Thankfully I have a plug which came with my S20 Ultra.
This is also one I have purchased, Anker is good hardware:
https://www.amazon.co.uk/Anker-Charger-Durable-PowerPort-Included-White/dp/B08LPCJ1YX/ref=psdc_13265...
Thanks,
Hi, same here no plug no ear phones, it's like beggars belief we are paying for a new phone and we don't get the usual things.
@PrincessTan111
You do know right you pay for a phone not the chargers. You call them usual because that's what you got used to.
But with the throw away society we have today means everyone has charging wires spare in the house.
What phone did you have before the S21?
Just seen one your old posts.
You had an S10.
This charger will fit your S21
Hi I had the s10plus. So using that wire just found it odd.
