close
Restart your phone
Robbaggio
I just received an upgrade to Galaxy 52 around a month ago, however i keep getting the below message coming up and can't seem to get rid of it, this can be through day.through night which is very frustrating, anyone know how to sort this?
Restart your phone, An SD card was removed unsafely, to prevent your phone from restarting, save unsaved data and restart now
@Robbaggio  So you have a SD card in the device ? If you do it might be worth getting a new one.
mikeliuk
Looks like a pretty common problem (Samsung) per the below. A faster microsd card or just swapping the microsd card fixes for some.
Some time ago there was the option to merge the microsd capacity with the on-device capacity and that corrupted twice for me before the option was removed.
Even a straight mount requires frequent backups on my Android devices but I've been lucky that a restart has so far allowed successful mounts after seeing output suggesting corruption. Good luck! 🤓
https://eu.community.samsung.com/t5/galaxy-s10-series/an-sd-card-was-removed-unsafely-to-prevent-you...
