close
Re hub
Kev1969
My EE hub drops out looses signal 3 times a day, just starts flashing then starts back up again without doing anything after about 2 minutes??
Hi @Kev1969
Welcome to the EE community
What device is it that you're trying to use?
Do you have an EE mobile, and if so, is that having any service problems?
@Kev1969 : Welcome to EE's Home Broadband Forum.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
