close
Re: PAC code used but texts still sending from temporary number
gjw70
I am having the same issues using a Samsung A12.  I called EE and they were able to show me how to change the number on the phone, which worked, but this was with a Samsung S20.  Can you tell me how to change on the A12?
Thanks!
Christopher_G
Hi @gjw70
Try going into your contacts app. Above your list of contacts, it may say 'Myself' and you should be able to change the number in there.
Is that what you mean? Let us know how you get on.
