Re: Order tracking: pay monthly orders
Smac82
I don't suppose there are guidelines for delivery times when the order was in stock when placed? I'm waiting on an S21, ordered Thursday, but still showing awaiting confirmation. I have the order number.
Thanks!!
6 REPLIES 6
Christopher_G
Which colour and memory size did you choose, @Smac82?
I'll check our stock levels.
Hiya @Christopher_G
Its phantom white 256 (or thereabouts lol). It certainly says its in stock when I check the order details. Its an upgrade if that makes a difference to where you check?
Thanks again!
Christopher_G
Thanks, @Smac82
The current guidance for new orders is to 'expect dispatch within 7 days'. If you're worried about your order at all, I'd recommend speaking to our Mobile Care team to check it.
@Christopher_G brilliant, thanks for your help!! I'll keep an eye on the order updates!!
All the best,
Shona
jarkimond
Valued Contributor
Valued Contributor
Hi Smac - did your phone arrive yet?
@jarkimond yes!!! It came on Thursday!!
