close
Re: EE PAYG SIMs Deactivation.
yuri123
Hello Guys ,
My card it seams to be de-activated , please can somebody from the EE staff check if it can be activated again ? My de- activated number   is xxxxxxxxxxx - Currently i am abroad and i haven't used the card for a while .
Thank you in advance.
[mod edit: Please do not post phone numbers on the public board. Thanks!]
6 REPLIES 6
@yuri123 :  Sounds like it has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
yuri123
Hello,
Thank you for the answer.
I tried topping up or making a chargable call , but i cannot do that.
Is there any other way to activate the sim?
Thank you.
I can only answer that if you tell me how long?
Since middle of march this year
That's about 7 months of non-use. You should be able to get it reactivated by calling CS.
Hello again.
No i am not able to make any outbound calls or messages , i can clearly see that my last add on was on 20th of march by messages on 150.
I was wondering is there another way to activate the cartd ?
Thank you.
