close
Power back-up for smart router
dseabrooke
Home worker here - looking for recommendations on how I can add some resilience to my broadband in the event of a power cut. If the power goes, I go with it!
Do I need an UPS unit from Amazon, or maybe a battery that supplies the voltage the plug-in transformer supplies?
@dseabrooke  You want a UPS unit.  This needs to be plugged in permanently with the router then plugged in to this.
7 REPLIES 7
@dseabrooke  I would also ask your employer to fund or at least part fund this.   After all it benefits them more than you.
IT-4BusyPeople
The product designed for this purpose is the Huawei BBU15-D Battery Backup Unit, which BT used to supply with its FTTP installations. This plugged into the mains and took 4x AA rechargeable batteries(*), additionally it came with a 12v cable so it could plug straight into the router.
However, an Internet search for these and other UPS/Battery backup for router devices indicates they are no longer as readily available as they were 1~2 years back.
There are several units being advertised on Amazon claiming to be suitable for routers, however, I note they provide a maximum output of 12v 1a - the EE routers all require a 12v 1.5a power supply. Having accidentally attempted to use 12v 1.5a power supplies on routers requiring 12v 2a, I would not recommend attempting to use these devices. [Aside: using 12v 2a power supplies for 12v 1.5a equipment doesn't cause problems as the equipment will only draw 1.5a.]
I also would not recommend using a UPS intended for a computer, unless it is also being used by the computer. This is because the energy draw of the router is typically too low for the UPS to register and so can result in battery drain and damage.
(*) This is useful as the batteries will cease to hold charge after a few years and so can be easily replaced by any rechargeable battery available on the high st.
In general, my experience of power cuts is that they are mainly short, hence simple battery solutions will work, for longer outages (4+ hours) where laptop batteries are starting to run low the only real solution is to get in the car and visit somewhere outside of your area...
Unless you're in an area prone to power cuts, is it worth the hassle? I tether my phone to my PC if my broadband goes down, assuming my PC still had power.  If I lost power completely, I'd just wait till it comes back, work can wait!
IT-4BusyPeople
Hassle?
I've located the following solution:
1. Router only, giving circa 2 hours of operation price £40.
iPower 12Vdc UPS System
2. Something a little more substantial, but at a slightly higher cost:
RGL 1202SM-1 12V 2A Power Supply with Battery Backup
3. A DIY option:
DIY Mini UPS for WiFi Router V3.0 | 12V Mini UPS | Work From Home
Personally, option 1 is the simple solution and would ensure the router and line continue to work through minor power fluctuations. Which if you are an EE mobile user and have a WiFi Calling enabled phone is useful. Obviously, if you are using a desktop etc. then you will also need a proper UPS to cover these, personally I only use one that gives circa 20 minutes of runtime - to cover power fluctuations; if the power goes out for more than 10 minutes then its probably going to be out for a few hours, so best to shut everything down cleanly.
Aside: Just for completeness, Powerline adaptors stop working with power outages and UPS's won't help. So if your desktop connects to your router via powerline adaptors you may have to rethink your connectivity.
IT-4BusyPeople
Its not just events outside of the home that can cause problems...
Currently, I'm investigating why my central heating system has decided to cause the RCD to trip and thus shutdown power in my house. Before that I've had other instances of the RCD tripping: kettle, iron, light bulb going on the blink.
The sensible use of UPS mitigates the hassle of having to recover calls and work in progress that are interrupted by such events.
Just been getting obsessed by the details of this....
A quick addition, if your broadband is actually FTTP and not FTTC, you will also need an iPower 12Vdc UPS System  for the Openreach ONT your router connects into.
