Please explain: Profiles & Access Point Names
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
18-04-2021 04:53 PM
Please explain possible use cases for profiles on the 4GEE Router.
- Who tends to use the Profile Management tool?
- Who tends to use Access Point Names?
- What are the pros and cons?
Per the user manual on page 23:
Profile Management
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-04-2021 08:24 PM
You would need to change or create a new APN if you were to change your Mobile Network Provider or sometimes if your change your SIM Plan on the same Network.
EE tend to use the same APN for all there SIM Plan types "everywhere" but for example Vodafone use different APNs for PAYG, Contract and Mobile Broadband.
APNs are part of a International Data Gateway Address which were developed within GSM 2G era for 2.5G GPRS, idea then was to introduce an Always On (Always Connected) Data connection to a Packet Switched Network rather than send Fax or Data over a Voice Network, so effectively ISDN for the Mobile Network. APN is also used as an Identifier which was important part of using Data whilst Roaming Abroad on different Networks.
In the early days, GPRS Mobile Data was designed to connect to all sorts of Stuff, other ISDNs, Different Data Networks, Banks, Finiancial, Secure Servers etc or just another GPRS Mobile on the other side of the Planet, but as it's mainly used for normal Internet Access now, most Phone Manafactures just put Global Settings in the Phones Firmware now which should in theory Auto configure your APN Settings for you when you insert your Network SIM.
Probably also worth pointing out that whilst you shouldn't need to change your APN Settings or a Routers Profile that contains the APN Settings you probably won't be able to if the Device is Network Locked or Network Firmware Restricted.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
18-04-2021 05:00 PM
They're really the same thing. It just that:
- Mobile phones tend to call them APNs.
- Mobile routers tend to call them Profiles.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
18-04-2021 05:04 PM
Why should anyone create a Profile /APN?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
18-04-2021 05:35 PM
A Profile/APN is always present. Its main purpose is to auto set the parameters needed to connect to your chosen mobile network.
The most popular change to it I've seen is to choose or override the setting for IPv4, IPv6 or both.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-04-2021 08:24 PM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-04-2021 10:35 PM
Usually you don't need to as it is auto populated upon 1st connecting to a fresh network.
