Personal hotspot not showing as an option on iphone
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2021 12:28 AM
I had a iPhone 6plus which had the option for personal hotspot. I upgraded to a new 8 plus and it does not have the personal hotspot option. How can I add this. I am on unlimited data SIM only. Thanks
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2021 08:09 AM
Hi @JamesM5
If you go into Settings, do you have Personal Hotspot showing?
If not, can you try a network reset, to do this go to Settings > General > Reset > Reset Network Settings, this will remove any saved WiFi passwords.
Let me know how you get on.
Leanne 🙂
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-06-2021 08:36 AM
HiLeanne,
thanks for the reply. The option was not in settings as you would expect. A reset did not work.
however, I solved it. It was in a further menu ‘mobile network’. Once activated there then it appears in the menu choices in settings.
thanks for your response though.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-06-2021 09:42 AM
