07-12-2020 04:28 PM - edited 07-12-2020 04:30 PM
Hi, I am out of contract and need to leave EE. Unfortunately signal is very poor both at home and work ☹️
I tried online through My EE and via Text but both said I could not as I have multiple accounts, only I am leaving. Tried on-line chat but came back as unable to help.
Currently unable to get through on 'phone. Any advice appreciated.
Solved! Go to Solution.
on 07-12-2020 04:49 PM
Hi @Theshed and welcome to the community
You may not be aware, but with EE's WiFi calling service, then anywhere you have access to WiFi, the quality of your coverage becomes immaterial.
You can continue using any compatible phone to make & receive calls, send & receive texts, entirely as normal anywhere that you have a WiFi signal.
If you have multiple lines on one billing account, then as per "how do I leave EE - help page" , you need to either use myEE online, or call C/S on 150.
on 07-12-2020 06:16 PM
Hi Thanks for the input. I currently use the WiFi calling at home but I do not have that access in work. Also it does not appear to work if someone calls me from a non WiFi connected 'phone.
The 'My EE' online tells me I can not use that service due to having multiple accounts and 150 has been unable to connect. 🤔
on 07-12-2020 06:23 PM
🙄Just thought, it may be signal issue. I will call on landline.
Thanks for help.
on 07-12-2020 07:35 PM
@Theshed wrote:
Hi Thanks for the input. I currently use the WiFi calling at home but I do not have that access in work. Also it does not appear to work if someone calls me from a non WiFi connected 'phone.🤔
Just on this note and by means of information, I suspect you may be getting confused with data-based apps such as WhatsApp or Facebook Messenger, that allow "calls" between users of the same app.
WiFi-calling lets you use your phone as normal without any need for network signal. That means making & receiving calls, sending & receiving texts entirely as normal, irrespective of where the call is to or from.
A landline user calling you, for example, won't know whether you're on WiFi-calling or on the mobile network, they will call you as normal.
on 07-12-2020 07:53 PM
Hi, Yea it's a strange one. If I call out on WiFi usually this is no issue, provided I am connected. But if someone calls from a non enabled 'phone, usually my Dad, then the 'phone rings but when I answer I cannot hear.
Then follows a 'round robin'. He calls my Brother, who calls me to ask what wrong !?
Sending Texts are also pretty impossible.
But unfortunately there is no WiFi where I work and no EE mobile signal either.
Strange as coverage checker say it good, yet other network which is 'average' is actually better.
on 07-12-2020 08:04 PM
I'm taking it as read that you're on pay-monthly, but out of interest what model of phone do you have?
on 07-12-2020 08:32 PM
'phone is a Nokia. Think it a 5:1
And yea, pay monthly
