close
Ordered when out of stock.
broccabrad
Hello, I ordered the s21 in phantom grey on the 21st of the month. It's now been back in stock for the past 3 days yet I've not heard anything else about the upgrade, I need to send my old phone back so was hoping to find out when it's coming, thank you!
9 REPLIES 9
Leanne_T
Hi @broccabrad
Which size Samsung S21 did you order?
Thanks 🙂
Hey Leanne. Just the regular S21 128gb version
Leanne_T
Thanks @broccabrad
Was this the Phantom White?
If so, this is currently showing out of stock, available to order and to expect despatch within 14 days.
As soon as we have an update on your order we will be in touch 🙂
It wasnt the phantom White. It was phantom grey the second one on the list
Leanne_T
Apologies @broccabrad
I would suggest getting in touch with our Mobile Care team, they will be able to check the order for you and give you an update 🙂
Thanks 🙂
I have the same issue with the s21 5g 128gb Violet
It brings two concerns for me
1) The old phone is meant to be with the recycling company EE is using for 6 July but that is looking ever less likely and that could mean a £650 fine for me
2) I am going away for a week 5 July so I fear any extension to the recycling I seek will be affected by this. I would not have ordered if I was to know there was a long long backlog.
Leanne_T
Hi @ewhite
When did you place the order?
Thanks 🙂
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
22nd of June
Leanne_T
Thanks @ewhite
The Samsung S21 5G 128GB in Phantom Violet, is showing Out of stock now
Available to order. Expect despatch within 14 days.
If you get in touch with our Mobile Care team on 150, they will be able to help with the trade in and go through your options with you.
Thanks 🙂
