MyEE perks
Vonnym8
How do I get my EE perks?
N_ro
If by nhs discount etc once your work email etc has been verified they will email you and then you log into the website and there’s a section for perks you generate the code and then call 150 and they will add it on for you it’s frustrating but it’s the only way to do it
Christopher_G
Hi @Vonnym8
Have you registered on the EE Perk Portal?
