For up-to-date information and comments, search the EE Community or start a new topic.  |
31-05-2021 12:27 PM
Intermittent problems with EE connecting to IPad and iPhone. Broadband works on main computer and Amazon Firefly but not Apple products. Anyone else having problems? Engineer came out but still intermittent issues which is proving impossible to chair Zoom meetings.
31-05-2021 12:32 PM - edited 31-05-2021 12:35 PM
For an EE Smart Hub, but not an EE Smart Router, try separating the wireless channels. On the Advanced / Wireless Settings page of the SH there is a button near the top to Separate the Bands. Turn it ON. Then the 5GHz SSID will appear starting with "5GHz-" & the 2.4 GHz SSID not starting with "5GHz-". Then connect your devices to the 2.4 GHz SSID if they can't do 5GHz. The Smart Router doesn't allow this.
Apples in particular are not happy with combined WiFi bands.
31-05-2021 01:08 PM
@anivo   Have you tried doing a network reset the the devices?  This will wipe all network connections and you’ll have to set them up again.  As it’s 2 Apple devices I assume they are both on the same Apple account and if they are they would of shared the WiFi network setup from one device to the other so if one had issues the other will probably have the same issue.
 You’ll find the network reset in
Settings>General>Reset>Reset Network Settings. Do both devices and see how it goes.
31-05-2021 01:09 PM
Hi Thanks for your reply. When I first had a problem with a new router, the wireless settings were split but having had all these issues now, an Engineer came round on Friday and put the two together but it is still a nightmare.
31-05-2021 01:10 PM
Yes they are both on the same account, so will give this a try now. Thanks
31-05-2021 01:22 PM
Brilliant and they are both working at the moment. Fingers crossed that the internet doesn't disappear again. I guess a lot of people must be having the same problem. Thanks for your help.
31-05-2021 01:22 PM
I should split them again!
