Hi
IONELA8
I need help to change my password wifi,I appreciate your help
@IONELA8 : Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
Northerner
Hi @IONELA8
Is this password on your router or your phone? If your router which one do you have?
