close
Andrea27
hi I cannot find the SIM card with my password on it and I have two new devices that I cannot sign in to my 4gee mini router what do I do?
SIMs don't have pwds on them; it's the mobile router that does.
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
