07-08-2020 08:42 AM
Hi
i have been in touch with customer support this week as my new Apple Watch is not connecting to my data plan. I have tried all steps required (unpair, update software, turn off WiFi).
In the Watch app the watch is showing as not having a network provider or ICCID number.
when I try to sync a data plan I get this webpage message every time:
Mobile data cannot be set up with the price plan you have.
You need to be on an EE Pay Monthly phone plan or Phone Sim Only plan to be able to add an Apple Watch Subscription to your account.
this is despite me purchasing a watch plan already and being told on the phone it is setup correctly and there is no apparent issue on my account.
Information from Tech Guru team (?) is that there is an EE wide issue merging phone contract and watch contract plans. But there are posts about this same things spanning years on here. I have been told to just keep trying every 48hours. I have already been offered one payment discount as essentially I am not getting the full function for the cost I am paying.
beyond that I just wanted it to work and I’m not sure just “try every 48 hours” is reassuring.
It was raised as a complaint (by the customer support) as they said that helps it create a ticket for the Tech team and I still have the complaint ID number if that is needed? However that ticket was closed because it was an already known issue. So I am not sure how I can chase it up and move to a resolution?
any help and advice from everyone would be great.
14-08-2020 08:26 AM
Hi, have sent a message.
27-08-2020 07:11 PM
I’m having exactly the same issue since I got my watch as of today and have had very much the same sort of responses as you Ashley. It’s pathetic EE! The sceptical side of me says this wouldn’t happen if customers got their watches from yourselves?! Rather than being fobbed off why is a reason not being given, as to me surely the plan could be added from your end?
27-08-2020 10:38 PM
Sorry to hear this as I know it’s infuriating when you know it can be solved.
interestingly enough, based on your comment , mine was purchased with EE. Whether it made any difference I don’t know.
what I will say is THERE IS A KNOWN SOLUTION. Mine is working now however the really poor show is the fact it took me five or so phone calls and also the calls I received from EE on top of that to ‘check’ the status of my issue. Plus messages here.
it came across to me that’s it just pot luck whether you get through to someone on the phone who is willing to transfer your issue up the Levels of Knowledge and tech support. This isn’t supposed to be rude but the first call handlers you get to simply do not know the way to fix it, they have to escalate your case. Twice I spoke to someone who was evidently aware of what the problem was and took the relevant details about my phone and watch and then a day or two later phoned me back to relink my data plan and it was working in minutes.
keep on at them, tell them you’ve done all the normal things (unpair, re pair, turn off WiFi on both devices then try to connect data plan, updated software on both devices) as that’s what the first level call handlers will simply suggest.
make sure you get a complaint ticket number too as that’s only way I got call backs to check on things. Plus a refund of costs to cover time when I couldn’t use the device despite paying for a plan.
the final person who helped me said EE know of the issue, don’t know why it happens, but know how to fix it. Don’t know why random people have to be so persistent to get it sorted.
28-08-2020 12:22 AM
28-08-2020 12:23 AM
That’s brilliant info thanks. Glad you got yours sorted. I’m scheduled to have a courtesy call next week from them. I bet if my 3 mobile plans and broadband were due up now and I threatened to leave suddenly there might be a miracle cure!!
02-09-2020 01:32 PM
Hi, have you solved your problem?
I'm having the same issue here.
02-09-2020 04:29 PM
02-09-2020 04:39 PM
06-09-2020 02:51 PM
So this is a heads up to those with this issue. I spoke to a tech guy the other day who sorted this problem. If you have mobile and broadband plans with EE, you have them linked to your EE app and try to add the plan to your watch, the site doesn’t understand what plan you’re linking it to, hence you can’t get the Apple Watch plan. The tech guy (Alan I think his name was) removed the broadband plan hence allowing me to set up the plan via Apple Watch app on the phone. He then reinstated the Broadband plan on my app. As another tip, when I logged in to do this I manually inputted my log in details rather than touch screen them. To test it out, once you’ve done this and had confirmation the plan has been set up. Turn your phone off and you should see your watch mobile data aerial symbol turn green. If not just touch it and make sure mobile data is on. I’m not very tech minded so hope this is a basic enough explanation for those oike
me to understand.
