close
Fibre in Worcester is down to 12MB/s at present
mkharper
Any one else experiencing disconnects?
Started withing the last hour and now stuck on 12MB/s.
@mkharper : Welcome to EE's Home Broadband Forum.
BB issues are rarely localised but are more likely to be an issue with your own connection.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
