close
Facebook newsfeed won’t load on iPhone
Donna03
Hi, I have a new iPhone 11 and the Facebook news feed won’t load on the app  only a few posts. Tried various things still isn’t working.
9 REPLIES 9
James_B
EE Community Manager
Hi @Donna03,
Are your other apps updating as they should?
Hi James,
yes all other app working fine.
James_B
Hi @Donna03,
Have you checked to see if there are any updates available for the Facebook app?
Yep Iv checked no updates, Iv deleted and re installed the app. Re - set my WIFI and tried on mobile data.
@Donna03 : See Switching Content Lock OFF or ON . It is switched on on new & upgraded contracts & seems to affect social sites. If just switching it OFF doesn't help, try switching it to STRICT, reboot your device and then switching it to OFF. That is seeming to do the trick.
Hi, thanks I just tired that still no luck. It only loads some of the news feed said page is not available  at the moment.
Katie_J
Hi @Donna03.
Are you able to log in OK via Safari?
Katie 🙂
Hi, yes when i login via safari I see a few posts then it says page cannot be loaded at the moment same as the app
Katie_J
Hi @Donna03.
Thanks for trying.
Is this the same if you log in via a Computer or Laptop or on any other device?
Katie.
