12-05-2021 11:26 AM
Hi All,
Wondering if anyone can help. I upgraded from ADSL to FTTC in April and I was originally told I would get estimated between 64Mb/s and 71Mb/s and then I upgraded to Smart wifi and it changed to 52.3Mb/s and 58.1Mb/s
I check the BT Whole checker and it says between 60 and 80 Mb/s yet my router syncs at 64MB/s. I know my line is capable of more as the Green box is like 0.3km away. I think I have DLM active but can anyone help?
12-05-2021 11:51 AM
DLM is forever active.
12-05-2021 02:16 PM
| 80 | 63.7 | 20 | 19 | 57.1 | Available | Available | -- |
| 80 | 60 | 20 | 17.4 | 49 | Available | Available | -- |
| 330 | 30 | -- | Available | -- |
| Up to 16 | -- | 15.5 to 17 | Available | Available | Yes |
| Up to 16 | Up to 1 | 15.5 to 17 | Available | Available | Yes |
| Up to 8 | -- | 7 to 8 | Available | Available | -- |
| 2 | -- | -- | Available | Available | Yes |
| 2 | -- | -- | Available | -- | -- |
| 63.51 | 15.31 |
| 19 | 1.25 |
| 2021-05-08 | 2021-04-17 |
| Available |
| Available |
| N |
| 29-04-2021 |
| N |
| N |
| Y |
12-05-2021 03:38 PM
Well, you are just about within the expected range for your line.
What are all EE's estimated speeds which you'll find in your MyEE for BB under Your broadband speed?
12-05-2021 04:06 PM
Minimum Fibre Download Speed is 52.0 Mb/Sec
Maximum Fibre Download Speed is 57.8 Mb/Sec
Minimum Fibre Upload Speed is 15.6 Mb/Sec
Maximum Fibre Upload Speed is 17.3 Mb/Sec
Minimum Guaranteed Download Speed is 46.80 Mb/Sec
But that wasn't what came on the first order email..
12-05-2021 04:15 PM
They're only estimates. Take them with a pinch of salt. You are beating all of them
Anyway an upgrade to Smart WiFi can't possibly change your sync speeds which is what all these estimates are about.
12-05-2021 04:48 PM
But this was what i was sent when i first ordered fibre.
So confused.
| Download Speed | between 64.0 Mb/s and 71.1 Mb/s |
| Upload Speed | between 12.5 Mb/s and 13.9 Mb/s |
| Minimum Guaranteed Download speed | 57.60 Mb/s |
12-05-2021 05:26 PM - edited 12-05-2021 05:33 PM
They're only estimates. Take no notice of them. They're not facts. The only speed that matters is the one measured by the router and whether it's about what is to be expected. Yours is.
Put another way: The 1sr set of EE estimates were reasonably in line with BTw; the 2nd set are a load of baloney.
12-05-2021 06:48 PM
Okay thank you, just annoying because I know its capable of more but nevermind.
12-05-2021 08:29 PM
Which exchange and cab number? You omitted those from the checker result.
