15-11-2021 01:27 PM
Hi
My mini wifi has stopped working. It connects to my PC via USB and shows up, but using 192.168.1.1 refuses to connect. Wifi also not working.
Any Ideas?
15-11-2021 02:26 PM
Hi @alaff02
Have you tried resetting the WiFi device?
Do you have data remaining from your plan or pack?
Thanks 🙂
16-11-2021 07:50 AM
Yes and Yes.
The small reset button has no effect no matter how long I hold it down for.
16-11-2021 07:54 AM
Hi @alaff02
Thanks for coming back to me.
Have you tried doing a pin reset of your device?
If you locate the pin reset hole on the back of the device, then press and hold this for 15 seconds using a pin, the device will be reset.
16-11-2021 07:55 AM
Yes that's the pin reset I've tried (next to the battery), but it does not do anything.
16-11-2021 07:58 AM
Thanks for trying @alaff02
In this case, please get in touch with our Tech team, they will run through some further trouble shooting with you.
Let me know how you get on 🙂
16-11-2021 08:00 AM
OK, will do.
16-11-2021 08:01 AM
