EE 4G home Broadband buffering on ITV and All4
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
14-10-2021 10:03 PM
Hello, I have EE 4G home Broadband with a new Router 2. The Router indicates 4 out of 4 lights for 4G signal level and the speeds through Ookla speed tests are about 60-70 Mbps down and 15Mbps up. I use the broadband all day for Teams call and things and there is no buffering, YouTube and BBC iPlayer are also fine. For some reason though the All4 and ITV hub apps (on both a firestick and YouView box) buffer and pause badly. I have run a speed test on the firestick browser and that reports 20Mbps. I have tried running the Firestick through a VPN to see if that would get round any throttling from EE but it doesn't help. I have reset the devices and cleared caches but no better. Any thoughts welcomed
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
14-10-2021 11:28 PM
Try changing the Routers APN Settings to IPV4 Only.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-10-2021 08:22 AM
Thanks for the reply, the router's APN settings are already set for IPv4 only.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-10-2021 08:42 PM
If everything else works fine but All4 and ITV have a problem, the next test is to try these on multiple devices.
If everything else works fine but All4 and ITV have a problem on multiple devices, it's quite likely it's the All4 and ITV services that have the problem.
The other play may be to move the SIM to an unlocked mobile and try the hotspot.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
18-10-2021 10:27 AM
HI, we've have the same problem, but after talking to friends and colleagues who are on various different connections with various other suppliers, it seems the issue is with ITV player (STV player in Scotland) and i would imaging if All4 is on the same platform, then that's likely to be the same issue. We've given up trying to watch anything on demand using ITV/STV player for this very reason. We also hate the ads that keep interrupting too 😉
