Does 4gee WiFi have high latency like mobile hotspot?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-01-2021 12:04 PM
About two month ago I bought the unlimited data plan 4g data. I bought this because my home WiFi was very slow and I needed to access my university computer using cloud service. Unfortunately, although I obtain high speeds on the speed tests, the latency is always high. I need a latency below 30ms to comfortably use the cloud computers. Will inserting my phone sim into the 4gee WiFi help? Will it reduce latency? I have really good EE coverage to my house. If that doesn’t work, what other student budget friendly solution is there?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-01-2021 02:32 PM
Hi @Iseeu12362,
Your phone SIM would perform exactly the same as your 4GEE WiFi SIM. Does the coverage checker show any problems in your area?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-01-2021 03:14 PM
thanks for your reply. No there are no coverage issues, just high latency (50ms). I need something below 30ms.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-01-2021 03:32 PM - edited 04-01-2021 03:34 PM
Hi @Iseeu12362,
If there aren't any current network issues, it may not be possible to improve your current latency.
Our Tech Gurus will be happy to take a more detailed look if you get in touch.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-01-2021 09:38 PM
I think you are being rather optimistic.
Lag of 50ms isn't high at all. If I remember correctly, typical lag on an ADSL connection is around 20-70ms. Around 30ms is as fast as it is realistic to get....only very good connections would be lower than 30ms.
I don't really understand why you think you need latency under 30ms to effectively use cloud computers? Latency only really matters when you need to get a very quick initial response from a server (e.g. playing games). Pushing or pulling data will be more dependent on bandwidth.
