01-12-2020 05:28 PM
Good evening and let me first of all say I am a struggling Granny - trying to master
my new Upgrade Xs IPhone without bothering my children or grandchildren so please forgive my ignorance.
I have managed to set it all up I think but I am unable to make or receive phone calls.
I have also managed to sort out how to keep my old number and it seems to be recognise d but still can’t get the phone to
work.
01-12-2020 05:35 PM
Hi @Juliahannan
What happens when you try to make or receive a call?
Is your phone showing signal bars?
01-12-2020 09:56 PM
Thanks for getting back.
No - no bars showing
01-12-2020 09:59 PM
Tried ringing landline but it just comes up Call Failed and there is no dialing
Tone or ring
02-12-2020 08:39 AM
Hi @Juliahannan.
Have you tried restarting the phone?
Have you had signal at all since you go the phone?
Jon
02-12-2020 08:53 AM
02-12-2020 08:57 AM
Good morning Jon
Yes I have restarted phone a number of times but still nothing.
No bars on top left corner. I noticed this morning an EE logo flashed up and flashed off again quickly.
I’ve never been able to use the phone to make or receive calls since I first
set it up a few days ago. Everything else seems to be OK. I was worried about
how to transfer my photos but they appeared on my new phone this morning
02-12-2020 09:01 AM
Thanks @Juliahannan.
I'm glad your photos have been transferred over.
Could you try removing your SIM card, giving it a quick clean, then put it back in the phone?
Jon
02-12-2020 09:04 AM
Well funny you should say that! I had a bit of trouble inserting the new pin initially partly because I put it in the wrong way then realised that you had to match up the corner to make it fit! But yes I have now removed and inserted it a few times just to see if
that worked but it didn’t
02-12-2020 09:05 AM
As you can tell I’m a complete novice!!
