close
Connect Echo to Huawei AI Cube
ahl1
Hi - anyone been able to connect another Echo Dot to the Huawei AI Cube so that you can have another Alexa in a different room to the one built into the Cube? Tried through both the Alexa app and the website but it cannot seem to connect the Dot to the wifi network being produced by the Cube (have connected the Dot to another home network, so I know the Echo works OK and have some TP Link plugs connected to the Cube wifi, although they did not set up on auto but needed to use the longer method, and I have phone and laptop connected to the Cube wifi, so I know that is OK). The Cube is running on EE 4G mobile data network. TIA if anyone has actually succeeded with this.
@ahl1   You’ll be best off asking Huawei if this is possible. It’s not a network connection issue but a compatibility issue with the 2 devices.
you might even be better off asking on the 3 network forums as the Huawei AI Cube isn’t sold by EE.
Thanks. I have, but thought I would ask this community too in case anyone else has come across the same issue.
