close
Change Esim From Secondary To Primary
Waqartx786_
Hi basicalky got an EE sim & i accidently put it on a secondary line rather than a primary line any help how to put it on primary line rather than secondary thanks
@Waqartx786_  You’re not going to need to request a replacement Sim card for the line that has been used on the eSim,  you then need a new QR code and then you need to make sure that you put it onto the line that you want use it on.
