close
Can you use a ethernet splitter
DAZZIE12
Can you use a ethernet splitter box with the ee smart hub as it doesn't have enough ports on it for what I need them for
If you mean an unmanaged switch, then yes.
6 REPLIES 6
  1. I'm not sure what you mean by a unmanaged switch I meant a normal ethernet splitter box not a switch one
I showed you pix!
pip11
Scholarly Contributor
@DAZZIE12An normal ethernet splitter box IS an unmanaged switch.
I don't think so, @pip11 . They are simple merge/demerge wiring used in pairs - see About Ethernet Splitters
pip11
I wouldn't call that a "splitter box". They also have to be used in pairs.
