18-05-2021 10:23 AM
I can't quite find the answer on other forums,
Basically, I've split my broadband channels so I can dedicate them where they're needed. Fine. Never had an issue, until now, so I can no longer connect to it? It shows up, it will try and even connect for a split second before telling me cannot connect to network. There have been no significant changes happened recently that could have caused an issue. Any suggestions would be welcome.
18-05-2021 01:57 PM
Hi @Gizmo333,
Welcome back to the community. 🙂
Do you see the same issue with all devices, or just one?
Have you tried restarting your router?
18-05-2021 06:11 PM
On which router?
19-05-2021 09:55 AM
Ee smart hub. And yup I've restarted it. Erm well originally all devices I had issues with but now my phone seems to connect to it. I haven't tried the other devices yet tbh. Work joys.
19-05-2021 10:37 AM
Hi @Gizmo333,
Please let us know if you are still experiencing issues when you test the other devices.
19-05-2021 11:37 AM
Post your Advanced / Wireless Settings page.
19-05-2021 06:51 PM
OK, so all the devices seem to be connecting now? It's the strangest thing... I honestly have done nothing yet its all good again?
Thanks for all the help folks. While this has gone a little unexplained at least it's working again... If I find a reason or cause I'll be sure to post it.
19-05-2021 07:09 PM
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
