Can I watch BT sport smart benefit on MacBook Air
ricey1234
Hi everyone
I have just purchased a MacBook Air to replace my iPad Pro 12.9 which has been given to my daughter. Previously I could watch BT sport fine on the iPad but can't find a way to watch on the MacBook Air.
Following a call to technical support they have suggested that a MacBook is classed as a big screen.
Please can someone kindly confirm if they have the smart benefit working on a MacBook Air?
Thanks in advance.
@ricey1234  Unfortunately no you can not your subscription is to watch via the device that the subscription is for.  If you purchase the large screen access you can.
Christopher_B
EE Employee
HI @ricey1234
Welcome to the community.
I hope you're well and having a nice day, are you up to much?
When you get BT Sports as a Smart Benefit, it's for the device you have that plan on.
You won't be able to access it on another device, unless you have the large screen add-on. You can find out more about this on our BT Sport Help page.
Thanks.
Chris.
Thanks for the reply. I will look into the big screen access.
