close
Broken Phone
Pen_Tay
My phone needs to be sent for repair, can I buy a cheap phone and put my existing sim in it.  I have an EE contract using Huawei phone
11 REPLIES 11
Leanne_T
Morning @Pen_Tay
Your EE SIM card will work in any EE or an unlocked phone, as long as the phone accepts the same size SIM card that you have, if not, you would need a replacement SIM card.
Hope this helps 🙂
Pen_Tay
can you tell me what size the sim card for Huawei P30 Lite is - is it nano?
Leanne_T
Hi @Pen_Tay
Thanks for the quick reply.
Yes, the SIM is a Nano SIM card.
Thank you for your help.
Leanne_T
No problem at all @Pen_Tay
All the best 🙂
Leanne,
Pen_Tay
My phone is being sent off for repair, I need a cheap replacement with w-fi capability - can anyone recommend a phone please
Katie_J
Hello @Pen_Tay.
Welcome to the community.
Are you looking for pay as you go or pay monthly?
You can find our full range of phones by visiting our online shop.
When selecting a phone you will be able to see the devices capability.
Katie 🙂
I want a stop gap measure to use my existing sim while the phone is repaired
@Pen_Tay   If your looking for a cheap device that you can get very quickly then your best bet is Argos.   Just make sure is on EE.
