close
Broardband speed on phone
IanWalton1
Hi, having broardband issues at home, phones are A12, broardband is through sky. Network speed says 69mbps yet a speed test is showing download speed of around 20mbps and upload of 12mbps from phone.
Is there anything I can alter on the phone to improve speeds to something a bit quicker.
TIA Ian
@IanWalton1  Try clearing any apps from working in the background and try the speed test again.  If your device is also doing other things it will have an impact on speed when you test it.    You can not do anything on the device to increase the speeds apart from closing apps so they are not running at the same time.
@IanWalton1 : Welcome to EE's Home Broadband Forum.
1. Post your full router stats. Obscure your names & any numbers in the BB Username & also the SSIDs. Full router stats are key to any speed & connection issues.
