close
Broadband randomly disconnects
MHarrisWales
For the last couple of weeks/months my fibre connection drops at random times of the day, often at the most inconvenient moment (ie when on a video call!!!). The light on the hub flashes amber/yellow for several minutes before reconnecting. I have already replaced the line filter with a new unit and the router is plugged into the master socket.
This appears to have become a relatively common fault judging by the comments in this forum. The disruption is not acceptable. Please advise the cause and solution.
Best wishes,
Mark Harris
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
