close
A20E SAMSUNG PHONE
George1960hay
Hi my phone keypad isn't working  properly  sometimes when u press a letter it doesn't go so u have letters missing in the words does the extended warranty  cover the repair of my phone thanks george
Christopher_G
Hi @George1960hay
Have you tried backing up all of your information and restoring the phone to factory settings? Doing that can help with keypad problems like this.
Christopher_G
Hi @George1960hay
George1960hay
Hi i asked a quistio the other night regarding  my A20E phone about the key pad not working properly  I got a reply saying to reset phone and try  I reset phone and key pad is now working thank you
Hi i have done the reset and it's working great thank you george
Christopher_G
Lovely stuff, @George1960hay.
Thanks for giving that a try, glad it's working properly now.
Chris 🙂
