23-03-2021 10:56 AM
EE online chat has been no help at all on this - they just say as long as I can access open internet then everything is working, which is totally untrue. Has anyone else had this issue and resolved it.
I have just moved from an Osprey2 to a 4GEE wifi mini, but am unable to login to myaccount.microsoft.com using the new device. I use the device for work and my large international company support helpdesk have been unable to resolve despite logging in being mandatory to work on our internal systems - they say it's the unit at fault. The error message I get is 'you cannot access this right now'. The SIM card works on an Huawei 3G plug in dongle and I can login perfectly to everything. The SIM card also works perfectly in an EE mobile phone configured as a hotspot. The SIM card still works on the old Osprey2. I have gone through the web interface and there's nothing I can see that looks incorrect - including looking at the hidden pages such as diagnostic, routingRules, urlFilter, vpn, ddns
If EE won't help or take the matter seriously, where do I go for support?
23-03-2021 05:47 PM - edited 23-03-2021 05:53 PM
Where did the new Device come from ? EE or A N Other like an MVNO on EE.
First thing I would check is that the APN Settings are correct and if it lets you, also within APN change the IPV Settings to IPV4 only.
APN settings are in a Sub Menu when you log into 192.168.1.1
APN: everywhere
Proxy: Not Required
Port: Not Required
Username: eesecure
Password: secure
23-03-2021 01:08 PM
Welcome to the community. We'll do our best to help.
So to recap and make sure I understand, when you put the SIM in a mobile or another 4G device, you're able to log into the page you posted? It's just when the SIM is in the Osprey 2 device that you can't log into it?
Have you spoken to Microsoft at all? They may have come across other users having a similar problem or have some diagnostic information they can use.
23-03-2021 03:11 PM
Christopher, not quite. The Osprey2, my old device works fine no issue at all logging in through Myaccount.microsoft.com. The same SIM card also works fine on a plug-in 3G dongle and with a 4G mobile phone being used purely as a hotspot. It's definitely a difference about the way EE implement security or something with the new device. Also remembering back maybe about 4 years ago, I upgraded to the device that at that time was the 'upgrade' to the osprey 2. That did not work either, and in fact I cancelled that contract as EE shop or online help could not find a cure so I went back to using my old device, but it's getting rather a tired battery now. Back then we did not have to log in through a microsoft page, but it just failed to work - can't remember the error message. Is there a specific hidden page on configuration through 192.168.1.1 on the 4GEE wifi mini that I haven't looked at yet - like one for a firewall, or specific ports not opened. I have been through all the forums I can find from Microsoft and nothing comes up with a similar problem.
23-03-2021 03:29 PM
OK thanks for explaining further, @david3thomas.
I've sent you a private message to get some information from you.
Please take a look and get back to me.
APN: everywhere
Proxy: Not Required
Port: Not Required
Username: eesecure
Password: secure
24-03-2021 08:02 AM
Great news. Yes the 4GEE device was supplied direct by EE and changing IP connection mode from the default IPv4v6 to IPv4 seems to have solved the issue. I've tried a few times rebooting and also just switching between BT broadband and the EE device and I can get in each time on either seemlessly again. Thank you
