close
4GEE mini repaired p/w gone.
SALSTE1
Valued Contributor
Valued Contributor
After a very successful repair job on the device none of the usual passwords work, under the cover etc, my a/c shows it as a BT device?. What p/w is usable to log in with smart tv. Phone does it automatically of course manually for telly.
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
