Wifi
Mart1n999
How do deconect wifi from my tv
Leanne_T
Hi @Mart1n999
Thanks for coming to the community 🙂
If you are connected to the TV using the iPhone hotspot, you can disconnect the WiFi by going into the iPhone Settings, Personal Hotspot and then turn off Allow others to join.
If you're connected to the TV using a different WiFi connection, please let us know as @XRaySpeX has advised and we can help you further.
@Mart1n999 : What Wifi? Do you mean you want to disconnect your TV from your Broadband router or is your TV using the hotspot on your iPhone?
Leanne_T
Hi @Mart1n999
