23-04-2022 12:57 PM
Reaching out for support!
I've tried multiple times to set up a custom voicemail greeting on my iPhone, but I'm constantly getting the following error.
The operation couldn't be completed. (com.apple.mobilephone error 1035.)
I would be really grateful if someone from the EE community could help me with this issue!
23-04-2022 03:36 PM
Hi @alittlebitloki,
Can you try and set it up with WiFi turned off and let me know if that helps?
23-04-2022 03:55 PM
@alittlebitloki Hold down the number 1 on your dial keypad and it’ll call your voicemail then just listen to the options given and select the option for a custom greeting.
