on 26-11-2024 08:40 PM
I can’t send texts anymore since I returned from two months overseas where I was using another eSIM (now deleted). I have gone through all the steps suggested on EE device fixes page including a master reset and still won’t send. Calls and texts are being received fine. It just comes up with a Can’t Deliver message. Help!
Solved! Go to Solution.
on 27-11-2024 10:43 AM
on 27-11-2024 08:24 AM
I’ve discovered this morning that I can send iMessages to other Apple users, but I can’t send texts to anyone at all
on 27-11-2024 09:28 AM
Hello @Annasteven.
Are you using a physical SIM or an eSIM?
Is your number pay monthly or pay as you go?
Are you connected to WiFi when sending iMessages?
Katie
on 27-11-2024 10:02 AM
Hi there Kate
its an eSIM, yes on WiFi and I pay monthly
on 27-11-2024 11:38 AM
That worked!!
I just toggled the network selection but that option wasn't available until this morning. It was like some of the settings options were missing
All good thanks so much 🙂
on 27-11-2024 12:05 PM
