08-01-2022 12:13 PM
08-01-2022 01:48 PM
Hi @Cobfox.
Welcome to the community.
Is this just happening with one number or is it all numbers that you try to call?
Jon
08-01-2022 02:29 PM
It’s just that number. No messages are being delivered either. I was thinking maybe the phone was lost/stolen
08-01-2022 04:28 PM - edited 08-01-2022 04:44 PM
Hi @Cobfox ,
You could additionally borrow another phone or use a public pay phone to call that number.
Do you have another way to contact this person, perhaps via a mutual friend?
It's quite possible that the number is no longer active or no longer used by the person or entity who previously had it, and this could be temporary or permanent.
When was the last time this number was active, if ever? Could you have been given an invalid number? Perhaps with a single digit typo?
I believe what you've heard is a disconnection tone. https://en.m.wikipedia.org/wiki/Disconnect_tone
08-01-2022 07:12 PM
Thank you for replying.
Yes that’s the tone I’m getting but it’s definitely the right number. Its been a week or so, firstly it was a continuous engaged tone and then changed to the disconnected tone. I have tried from a landline also.
08-01-2022 11:42 PM
Hi @Cobfox ,
If you hear the same thing using a landline, there's almost certainly an issue on the other end.
The timescale seems too sort for it to be a Pay As You Go SIM deactivated due to inactivity. https://kenstechtips.com/index.php/payg-inactivity-account-termination-and-credit-expiry
Typically a phone which is off would go to voicemail.
I can only speculate that the person may have been moving between mobile phone networks and there's been a hiccup in the transfer of the mobile phone, or the number has been accidentally cancelled.
Contacting via another method would seem the most sensible approach, unless this was your only method of contacting this person, in which case 😬
