Esim
Mirek6
Hi
Is still problem to use iMessage ( blue messages on iPhone) when I swap SIM card to e-sim card I had this issue before, I consider to change SIM cards but I would like to be sure it will work correctly
thanks for any help
Schockwave
Hello @Mirek6 ,
Welcome to the community,
With IPhone, IMesage will show as blue and text message will show as green, so you know if someone has Apple and uses IMessage. Not quite sure what your problem is, may need to make it more clear, what problem you have, as whether you use E-Sim or physical SIM card should not make any difference.
