samsung galaxy s20+
Marilyn444
Hi , can anyone confirm,  is mobile data better on or off in a poor signal area ? Does it use data allowance quicker
The only difference to data consumption would be that in any area where you have better speeds, then you can use data quicker. Poor signal does not necessarily equate to slower speeds.
If you disable mobile data on your phone, then any internet-based functionality will stop working unless you have a WiFi connection.
