24-10-2025 09:27 PM
Why does my phone cut off 15 minutes into a conversation, it's so annoying and it does it every time
26-10-2025 01:46 PM
Hi @LBKSB16.
Welcome to the community.
I’m really sorry to hear about your relative, and I completely understand how frustrating it must be to have calls cut off, especially when you're trying to offer support from a distance.
Since the issue happens every time you’re on a longer call, I’d recommend getting in touch with our Technical Guides. They’ll be able to run through some checks with you and investigate the issue further.
Debbie
24-10-2025 10:57 PM
If this is happening on every single call regardless of location, it could well be a device issue - possibly a battery-saving or some such.
When did the problem start?
26-10-2025 09:49 AM
26-10-2025 01:46 PM
Hi @LBKSB16.
Debbie
