Voicemail not working
Raph1506
Hi have a Samsung S9 and for some reason my VM stop working few weeks ago.
Trier all that bit on VM ON to 150 but it does come back with we are experiencing technical problems. Try VM off and that get accepted... really weird bit my VM still don't work
@Raph1506  Try “voicemail divert on” to 150
you could even try holding down the number 1 key on your dial pad and wait for that to call your voicemail then listen to the options given.
Leanne_T
Hi @Raph1506
Thanks for posting 🙂
If the advice from @Chris_B does not resolve this for you, please call us on 150 and the team will be happy to help.
Leanne 🙂
