Unlocking your EE mobile phone or device
James_B
EE Community Manager
We often see posts in the community about phone and device unlocking. So here's a quick guide on how to get your phone or device unlocked on EE.
Here are some quick facts.
  • All devices sold directly on EE since December 2021 are unlocked.
  • All Apple devices have been pro-actively unlocked, you can check by texting Unlock to 150.
  • All Google Pixel devices have been unlocked remotely.
  • All Samsung devices launched from the Galaxy S20 are unlocked.
  • Unlocking a device can now be done at anytime.
  • Unlocking a device is now free of charge.
  • You cannot unlock a device which is registered lost or stolen
If your device is locked, you can request it to be unlocked using the link below.
Request to unlock here
How do I know if my phone or device is locked?
For an Android device simply try a different network SIM card in your device. If it doesn’t work, it is likely that your device is locked. Text UNLOCK to 150 to check the status of your Apple device.
What is my IMEI number and how do I find it?
IMEI is your International Mobile Equipment Identity, a unique number used to identify your individual device. Made up of around 15 digits, the code is typically found behind the battery or in your device’s settings. You can also retrieve your IMEI by dialling *#06#.
I’m no longer an EE customer, can I still unlock my phone or device?
Yes, please use the new digital solution here
How will I receive my unlock code?
The new service will present the unlock details on screen, where you can request them sent in email to use later if you require. If you lose them, don’t worry, simply visit the link again and re-enter.
Important information
If we are ever unable to unlock a device due to software issues, we will contact you. We will then direct you to the manufacturer.
If you haven’t received your code within ten days and haven’t received a text saying we’re waiting for the codes from the manufacturer, please get in touch with Customer Care.
Did you know…?
Unlock codes are also known as: MEP code (Blackberry), NUC (Network Unlock Code), and subsidy PIN.
Unblocking is different to unlocking: Your phone or device can become blocked in several ways (for example, entering the wrong SIM PIN number three times in a row).
To unblock your SIM card you will need to use something called a PUK (Personal Unblocking Key) code.
For help with your PUK code see the help page >
If you have any further questions, let us know below.
95 REPLIES 95
Welcome to the EE Community, @Spookylibrarian
Does your daughter need to unlock her phone to use it with another network or unlock her SIM with a PUK code?
She needs to unlock her phone to use with a new SIM card - I've spoken to 4 operators and no-one has been able to help. She's going to try the suggestion from another user on here but the website is terrible.
Sent from Outlook for Android<>
Hi @Spookylibrarian,
What type of phone is it and when was it purchased?
Is the phone asking for a HUC, MCK or PUK code?
Yes, @Spookylibrarian , but with a SIM for another network?
Yes, they're in Singapore. Thanks
It's asking for a PUK - that might be because they need to speak to the provider in Singapore to get that sorted (we figured that bit out ourselves)
James_B
Yes, if it's asking for a PUK with the local SIM inserted, you'll need to request it from that network.
Casboy
I have just unlocked a Samsung A10. Tried with the 16 digit code given by the online form. Been to the EE shop and they couldn't unlock . I put in the last 8 and then the first 8 and the phone unlocked. What I cannot believe why this instruction is not given after receiving the 16 digit unlock code from the online form? Perhaps it could be included?
Leanne_T
Hi @Casboy
Thanks for coming here and leaving the feedback for unlocking the device.
We will share this suggestion to the relevant team.
Kb345
Hi, James
I have tried the *#06# to unlock  two old phones I have and both times I never get given the unlocking code, I even sent details to my email address and clicked the link and it still does not work. So what do I do?
