Turn on 5G using USSD Code
jof8
Hi, I have a Google Pixel 6A, sometime ago I used a USSD Code to turn off 5G as I heard that this saved battery on the Pixel phones.
I think the USSD code I used was ##4636## or something similar, but can't remember the exact one.
Now I want to turn the 5G back on again and I can't find the right USSD code that opens up the menu for selecting and de-selecting 5G.
Can anyone advise what USSD code I can use to turn 5G back on again?
jof8
I managed to fix it myself by the following settings:
System>Reset Options>Reset Mobile Network Settings
Can't you just do this using its Network Connection menu?
jof8
Londoner88
*#*#4636#*#*
General advice for all readers:
Take screenshots
And don't change anything you're unfamiliar with.
3G - WCDMA
4G - LTE
5G - NR
And yes, resetting network settings is best
Simple 🙂🙂‌. Thank you
