Keypad digits not working during phone call
AbbyG1
I cannot select a number on my keypad when given options during a phone call so I cannot ring EE with the problem. As I can't select a number for the option I want it cuts me off. Urgent as other calls I need to make too.
8 REPLIES 8
Have you been able to use keypad tones before? If so, when did this problem start?
Are you in the UK or abroad?
Northerner
Hi @AbbyG1
What device. Does the number keypad come up.
Yes as the other day I rang EE (so was able to select the option I needed) to report that my phone was showing I had messages when I didn't.  This has happened since that problem was fixed.
In the UK
Samsung S24.  Yes it does.  Can't call EE as I have to select a number to be transferred to the appropriate department.
Schockwave
@AbbyG1 , have you rebooted your phone to see if that works?
Yes I have and unfortunately not.
Rach_H
Hi @AbbyG1,
Welcome to the Community!
I'm sorry to hear you're having this difficulty. Are you able to call us on a friend or family member's phone, so our team can take a look into this?
Rach
Hi Rach
I will try that when I see someone otherwise I will try and get to a store tomorrow.  Perhaps there should be another way to contact EE if this happens.
Many thanks
Abby
