Second APN appeared. Why? How? Is it a security issue?
Markjh
I'm sure that the last time I looked there were no names listed under APNs.
I have one named:
EE Internet ("everywhere" is underneath this APN name) there is a circle to the far right with a solid dot in the centre.  It does not do anything when pressed.  Kinda glad because I don't know what I am doing!
SECOND APN (Absolutely sure this has just appeared)
APN name:
EE MMS ("eezone" under the name). No circle on the far right like the one described above.
Northerner
Hi @Markjh
They are on the SIM and perfectly normal. As you can see one is for MMS settings and one for Internet settings.
I normally ignore or delete MMS Pushed Settings on Devices and Phones, that way I shouldn't get unexpected expensive Charges outside of my Allowances from any Network like I have done in the past, some charges can be over 50p per hit.
The way I see it is if someone want to send me something outside of a normal Text / SMS Message rather than email or WhatsApp then I'm not interested in it.
